I believe I already introduced myself and posted many years ago when I joined.
For various reasons, my 06 Jetta with 153k miles here in Florida got no use for a few months last year. When I went to drive it, the brakes would not fully release when the pedal was released. I changed the brake fluid, including the clutch and it worked well again. It then again sat outside unused for a couple more months and now the slow release brake pedal and sticking brakes problem is back. I jacked up the front of the car and tested the front wheels by applying the brakes to see if they would stick. They did not. I then repeated the test for the back wheels with the same curious lack of sticking. The pedal stll returns very slow. All the rotors and pads are fairly new. I am greatly puzzled. I have not yet checked the one way valve to the booster, but that is the next thing on my list.
I do still need to change a noisy front right wheel bearing. Could a funky wheel bearing actually be the cause of the drag, even though it doesn't pull when dragging?
Any suggestions are welcome.
