98 tdi 207K miles got its first new clutch this week. The COCS won't stay in anymore. Can't be a coincidence. All parts including new slave cylinder are OEM. I found where VW had issued a TSB but they say its no longer in their system and the fix only adds a tab on the clutch mounting bracket that holds a rubber bump stop. The clutch dissengages all the way at the floor now so preventing it from going to the floor seems like a bad idea. I think I'm just going to leave it off. I can't see any purpose for it anyway. Anyone have any similar expierence or advice?
You mean it pops out when you press the clutch pedal down?
Make sure the fluid is bled because sometimes the master cylinder or slave cylinder gets a bubble stuck in there. You could loop a clean hose back to the MC and slowly pump it again and again until you think it's OK.
