1 - 11 of 11 Posts
I have a 2005 Golf TDI that seems to have a bad cluster. The immobilzer is tripped and I can't clear it. Over the past week, the tach, lights and beeping would sporadically Blink, beep and not work and the car would go into limp mode. It seems like a bad connection internal to the cluster, because it seems to start/stop when I hit a bump. I was able to reset things by pulling the Relay 109 out. But now that doesn't seem to be working.
A couple of questions:
1) Can I replace the cluster with a used one?
2) How can I read the SKC of the current cluster? I saw a post or two referencing VAG DASH or Vag Tacho..
3) Can I read the SKC of a used cluster?
4) Can I disable the immobilizer?
The dealer said it would cost ~$1000, and I am really not fond of that approach.
Any help would be greatly appreciated!
What error code(s) are you getting?
1. Yes but you can't change the mileage without hacking tools that often don't work. You need the SKC. A new one or one with only a few miles on it can have the mileage increased.
2. Take a look at the immobilizer FAQ article...
3. Yes.
4. Yes but it requires a reflash of the computer.
Codes and another observation
Just drove the car for over an hour without the heat, and it was fine....
This all started when the air temp got really cold, and I have been cranking the heat. Not sure it has anything to do with it but I am going to try to replicate it. Right now the car is idling with the heat blasting. I might be grasping at straws....
Here are the Codes:
Sunday,23,January,2011,12:37:52:26358
VCDS Version: Release 10.6.3
Data version: 20101206
Address 01: Engine Labels: 038-906-016-BEW.lbl
Control Module Part Number: 038 906 016 Q HW: 028 101 181 2
Component and/or Version: R4 1,9L EDC G000AG 6110
Software Coding: 0150034
Work Shop Code: WSC 00000 785 00200
VCID: 22419E578449
5 Faults Found:
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 162.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00001100
Temperature: 8.1°C
Duty Cycle: 0.0 %
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 000 - -
Freeze Frame:
RPM: 1680 /min
Torque: 148.0 Nm
Speed: 77.0 km/h
Load: 56.1 %
Voltage: 14.59 V
Bin. Bits: 00001000
Torque: 264.0 Nm
Torque: 180.0 Nm
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 000 - -
Freeze Frame:
RPM: 1680 /min
Torque: 148.0 Nm
Speed: 77.0 km/h
Load: 56.1 %
Voltage: 14.59 V
Bin. Bits: 00001000
Torque: 264.0 Nm
Bin. Bits: 00000000
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 000 - -
Freeze Frame:
RPM: 1680 /min
Torque: 148.0 Nm
Speed: 77.0 km/h
Load: 56.1 %
Voltage: 14.59 V
Bin. Bits: 00001000
Torque: 264.0 Nm
Torque: 180.0 Nm
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - - MIL ON
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 0.0
Readiness: 1 2 1 0 1
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 19: DTCs cleared
Address 17: DTCs cleared
Address 46: DTCs cleared
Address 56: DTCs cleared
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 9BWGR61J054012590 Mileage: 182920km/113661miles
Part No SW: 038 906 016 Q HW: 028 101 181 2
Component: R4 1,9L EDC G000AG 6110
Revision: 12345678 Serial number: VWZ7Z0D0437099
Coding: 0150034
Shop #: WSC 00000 785 00200
VCID: 22419E578449
4 Faults Found:
P1650 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 110.0 Nm
P1649 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Bin. Bits: 00000000
P1636 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 110.0 Nm
P1672 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 66.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00001100
Temperature: 14.4°C
Duty Cycle: 0.0 %
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 BL
Component: AG5 Getriebe 09A 0262
VCID: 76E992077841
No fault code found.
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
VCID: 346D680F2EBD
2 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication
01315 - Transmission Control Module
Address 15: Airbags Labels:
VCID: 55ABF58B8587
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 907 F
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 15234
Shop #: WSC 00000
VCID: 2C5D706FF68D
9BWGR61J054012590 VWZ7Z0D0437099
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00000
VCID: F0E5241F9A25
2 Faults Found:
49-00 - No Communications
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8C Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 00000
VCID: 37775F033FCB
Part No: 1C1959801A
Component: 8C Tõrsteuer.FS KLO 0202
Part No: 1C1959802A
Component: 8C Tõrsteuer.BF KLO 0202
Part No: 1C0959811A
Component: 8C Tõrsteuer.HL KLO 0202
Part No: 1C0959812A
Component: 8C Tõrsteuer.HR KLO 0202
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 G
Component: Radio ZSW 0016
Coding: 00031
Shop #: WSC 00000
VCID: 244D984F9E5D
End ---------------------------------------------------------------------
I personally would pull the 109 relay, open it up and EXAMINE all the solders on the circuit board with a good strong magnifying glass... I use the lens from an old fog-lamp. You may well find cracks around the 30 power post where it solders to the board. We used to have lots of problems with them!
Yeh! prove it lol.
The relay can cause running issues but I don't think it's related to the immo in any way. I could be wrong though and am willing to be corrected.:D
Also welcometomyturbodies hxcdirtydan.
1 - 11 of 11 Posts
