2006 TDI (BRM) with DSG, Package 2 - 205,000 miles
I have put ~1000 miles on the 2006 TDI w/ DSG that I bought a couple of months ago. It had some codes for the HVAC system and MAF (due to a boost leak that I fixed), but that was about it since the previous owner must have cleared everything prior to sale. I now have a small list of codes, and while everything seems to work fine (or well enough), I'd like to see if I can eliminate the causes of the codes. There is really only one which seems like it might be serious, so I will list that first.
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000602091049
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 51A2F556C8876BC746-8004
1 Fault Found:
17106 - Transmission Output Speed Sensor (G195)
P0722 - 000 - No Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 26
Mileage: 330105 km
Time Indication: 0
I have not been able to find much information about this one online, other than people experiencing failing mechatronics units or some sort of wiring issue. The only issue with the car's driving performance is that it will occasionally surge in 2nd gear and more rarely "hiccup" when shifting gears, usually in around-town situations where I am quickly changing between accelerating and decelerating. The G195 sensor is inside the transmission and accessing it or its wiring requires removal of the mechatronics unit, correct? Is there anything external that I can check, or some other issue which can manifest as this error?
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000133169
Coding: 06018E234004180000140000001400000028770B5C
Shop #: WSC 19303 444 54078
VCID: 2B5E87BE8A6B61171C-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 19303
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00111010
Fault Priority: 1
Fault Frequency: 2
Reset counter: 43
Mileage: 329815 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.50 V
ON
ON
OFF
OFF
ON
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 43
Mileage: 330011 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
OFF
I installed some OEM bi-xenon headlights with shutter control a week ago and modified the CECM coding according to the tutorial on here. On top of that I also re-coded the instrument cluster as British to get full 4 light high-beam functionality. The lights are working 100% properly. Is there some other setting somewhere that is tripping because it expects halogen low beams rather than HID ballasts?
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E0032965
Shop #: WSC 00000 000 00000
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 38
Mileage: 329281 km
Time Indication: 0
Date: 2000.00.00
Time: 19:11:43
EDIT: Apparently there is an XM tuner module installed in the car. Looks like I will be removing it since I do not plan to use XM radio.
Not sure what this means. It was there with the factory radio, which I swapped for a RCD-510 + 9w7 BT, and the code is has returned. What is it looking for which is either broken or missing?
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 18011403000774
Coding: 352002
Shop #: WSC 00066 790 00086
VCID: 7BFE77FEFA8B3197CC-802E
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 329281 km
Time Indication: 0
Date: 2000.00.00
Time: 19:10:44
I also upgraded the CAN gateway when I did the RCD-510 + 9w7 BT since I was not sure if I would run into battery drain issues. I listed all of the installed modules before removing the old gateway and selected the same ones with the new one. Any ideas here?
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 3668A6CA41292CFF73-8062
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 3776ABCE4623D5F768-8062
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
012 - Electrical Fault in Circuit - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Occasionally the doors do not seem to lock/unlock properly. I'd say it is 10% of the time or less. Would this be a door wire harness thing, control modules, or something else? It seems suspicious that both front doors are having issues simultaneously.
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5A89A6B47F6F2702-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
I assume that the heating element burned out. Where I live it does not get cold, and it has not snowed in decades. Can I just remove the thing entirely, or at least just unplug it and remove it from the CAN gateway?
VAG Error Code: 17106/2228
EOBD II Error Code: P0722
Fault Location:
Transmission Output Speed Sensor (G195) - No Signal
Possible Cause:
Speedometer improper reading.
Possible shifting problems.
Wiring/Connector(s).
Water damage at connector.
Transmission Output Speed Sensor (G195) faulty.
Possible Solutions:
Check Transmission Output Speed Sensor (G195).
Special Notes:
When found in 4-Speed Automatic Transmission (01M) Transmissions:
Check for any applicable Technical Service Bulletins (TSBs) for overlay wiring harnesses as mentioned on the 01M page.
The terminal connector(s) for the Transmission Output Speed Sensor (G195) and Vehicle Speed Sensor (G68) are the same and can be mixed up. This can give an "Implausible Signal". Verify sensors have the correct connector(s) using the wiring diagram and Technical Service Bulletins (TSBs) mentioned on the 01M page.
When is the code detected?:
The output shaft speed sensor failed to provide a signal to the Transmission Control Module (TCM) upon initial movement of vehicle.
Description:
The Vehicle Speed Sensor (G68) detects the revolution of the idler gear parking pawl lock gear and emits a pulse signal. The pulse signal is sent to the Transmission Control Module (TCM) which converts it into vehicle speed.
VAG Error Code: 00978
Fault Location:
Lamp for Low Beam: Left (M29) - Electrical Fault in Circuit/Open Circuit/Short Circuit to Earth/Positive
Possible Cause:
Lamp for Low Beam: Left (M29) faulty.
Fuse(s).
Wiring/Connector(s) from/to Lamp for Low Beam: Left (M29) faulty
Control Module incorrectly coded.
Possible Solutions:
Check Lamp for Low Beam: Left (M29).
Check/Replace Fuse(s).
Check/Replace Wiring/Connector(s) from/to Lamp for Low Beam: Left (M29).
Check Control Module Coding.
http://wiki.ross-tech.com/wiki/index.php/4-Speed_Automatic_Transmission_(01M)
VAG Error Code: 00979
Fault Location:
Lamp for Low Beam: Right (M31) - Electrical Fault in Circuit/Open Circuit/Short Circuit to Earth/Positive
Possible Cause:
Lamp for Low Beam: Right (M31) faulty.
Fuse(s).
Wiring/Connector(s) from/to Lamp for Low Beam: Right (M31) faulty.
Possible Solutions:
Check Lamp for Low Beam: Right (M31).
Check/Replace Wiring/Connector(s) from/to Lamp for Low Beam: Right (M31).
VAG Error Code: 02635
Fault Location:
Tuner not Enabled/Activated (Radio/Navigation Display Control Module (J503) Radio (J503)) - Intermittent
Possible Cause:
Digital Satellite Tuner in Demo Mode.
Digital Satellite Tuner not enabled.
XM/Sirius not activated.
Special Notes:
This fault code is only a note, it will disappear once the XM/Sirius Subscription is renewed.
VAG Error Code: 01044
Fault Location:
Control Module Incorrectly Coded - Intermittent
Possible Cause:
Reduced Functionality.
Control Module incorrectly either not coded or incorrectly coded.
Possible Solutions:
Check Gateway Installation List.
Check/Fix Control Module Coding.
See Vehicle Specific Diagnostic Procedures for Details.
Special Notes:
When found in CAN-Gateway:
On a Long Coded module, use the Gateway Installation List to check for unreachable or not registered control modules.
Then update the Gateway [Installation List] by altering the Gateway Coding manually.
On a Short Coded modules, refresh the original coding with the same value. For example, code it from 00006 -to- 00006 without making an actual change.
When found in VW New Beetle/Cabriolet (1C/1Y/9C): Comfort System, this may be a Bug in the Control Module Software that will be resolved by refreshing the Coding with the same Value as described above with the CAN Gateway example.
When found in Brake Electronics (MK60EC1) while the Coding is NOT all Zeros, check the [19-CAN Gateway] > [Coding - 07].
An incorrect LHD/RHD Configuration may cause this Fault Code.
When found in the VW Passat (3B) Gateway Controller: Vehicles built through January 2000, the Gateway Software did not take in account for the ABS Controller. This fault code should be ignored. New Software was implemented after February 2000 that eliminated this fault code, however the coding should not be changed to add the ABS controller.
VAG Error Code: 01553
Fault Location:
Motor for Central Locking: Passenger Door (V57): Lock - Electrical Fault in Circuit/Short Circuit to Earth
Possible Cause:
Fuse(s).
Motor for Central Locking: Passenger Door (V57).
Possible Solutions:
VAG Error Code: 00929
Fault Location:
Locking Module for Central Locking: Front Passenger Side (F221) - Implausible Signal
Possible Cause:
Door Locks not working properly.
Wiring/Connector(s) from/to Locking Module for Central Locking: Front Passenger Side (F221) faulty
Voltage Supply for Locking Module for Central Locking: Front Passenger Side (F221) faulty.
Door Lock Mechanics are stiff/partially seized.
Possible Solutions:
Check/Replace Wiring/Connector(s) from/to Locking Module for Central Locking: Front Passenger Side (F221).
Check voltage supply to front passenger's door control unit or to door main connector (lower right footwell).
Check Door Lock Mechanics/Operation.
Check/Replace Locking Module for Central Locking: Front Passenger Side (F221).
VAG Error Code: 00361
Fault Location:
Heater Element for Auxiliary Heater (Z35) - Faulty/Defective
Possible Cause:
Auxiliary Heater not working.
Fault Code(s) cannot be cleared.
Heater Element for Auxiliary Heater (Z35) faulty.
Possible Solutions:
Check/Replace Heater Element for Auxiliary Heater (Z35).
Special Notes:
When found in Auxiliary Heater, this Fault Code often cannot be cleared. Usually this Code implies that the Heater Element (Z35) houses the Control Module this Fault Code is stored in, therefore the Heater Element may need to be replaced to fix this.
