So I am in a bit of situation here, i paid for the premium content about a month ago, and i still don't have access to part 3 of the tutorial. My engine is out of my car for a few days now, and i just need to get it done and back into the engine. Does anyone know of another source for the a tutorial?
Alternatively, can someone please confirm that this tutorial would work for my engine.
https://www.techtips.ie/Contitech/vw-20l-cbdb-common-rail-engines-timing-belt-guide-1.pdf
Seems like it would, but it mentions engine code CBDB...however in the description it mentions the mk6 tdi cars.
Thanks for any help....cheers.
Also, that walk thru you posted is quite impressive.
Using that in conjunction with the myturbodiesel video should have you covered.
The only tricky thing I ran into was when I locked the crank cog I couldn't get the cam lock to fit in. Once I locked the cam in place, I was able to get the crank locked and carry on with the final timing check (rotate crank 2x by hand) before starting up the engine.
