VAG Error Code: 17125
EOBD II Error Code: P0741
Fault Location:
Torque converter clutch (TCC) solenoid - Performance or stuck off/No power being transferred
Possible Cause:
Automatic Transmission Fluid (ATF) Level not OK.
Transmission Sealing faulty.
Automatic Transmission Fluid (ATF) dirty.
Torque Converter faulty or incorrect Torque Converter installed.
Solenoid Valve 7 (N94)/Pressure Regulating Valve 4 (N218) faulty.
Torque Converter Pressure Valve faulty.
Valve for Torque Converter Clutch faulty.
Torque Converter Lock-Up Clutch faulty/worn out.
Possible Solutions:
Check Automatic Transmission Fluid (ATF) Level.
Check Transmission Sealing.
Check Automatic Transmission Fluid (ATF).
Check Torque Converter.
Check Solenoid Valve 7 (N94)/Pressure Regulating Valve 4 (N218).
Check Torque Converter Pressure Valve.
Check Valve for Torque Converter Clutch.
Check Torque Converter Lock-Up Clutch.
Special Notes:
When found in
VW Passat (3B): 5-Speed Automatic Transmission (01V), check Transmission Sealing (see TPL 2009761).
The NAR (North American Region) TSB 01-07-22 or 2011908 should contain similar information about the internal torque converter seal failure.
When found in the NAR (North American Region) Audi vehicles with the 01V/01L family transmission check for similar torque converter failure issues explained in TSB 32-07-02 or 2010879/10.
As taken from my
http://www.myturbodiesel.com/forum/f9/free-eobd-ii-error-codes-software-2919/ updated version.
