1 - 7 of 7 Posts
What dose a check engine light mean ,and what is the first Diagnostic check to look at on the computer? i have the (vag com) tool?
It can mean a lot of things.
thanks i have the VAG-COM/VCDS} How do i scan for error codes??
How long have you add VAG-COM\VCDS and you have never done a full scan?
Is it a genuine cable or a cheap Chinese cloned cable of fleabay? As good forum won't answer question about those.
You can save the old PDF manual from Current VCDS Release
Ross-Tech forum
1 - 7 of 7 Posts
