It's not that hard, remove the timing belt cover and you'll see the sensor there, a bolt holds it in place. Then trace the wire. Here is a picture of the belt (similar engine) showing sensor right at 4:30 position of the camshaft.
FYI, if the camshaft timing is way off it will also throw a camshaft sensor problem.
the distribution must be removed in order to remove the sensor?
if this sensor does not work well, it can create air vent with the 2 and the 3 march 2500 ai3000 rounds?I have no error code.thanks
