That is something to do with the glow plug. The new cars have pressure sensors built into the glow plugs. They are supposed to adjust for low cetane and engine wear. If one fails, the car uses the readings from the other sensors. I'm also guessing they didn't do anything about it. Go back and don't clear the CEL.
Abs. Pressure is air pressure. 1 bar probably means ambient air pressure? The older log showed 0 bar which I'm guessing means either it didn't sense anything or the computer reported 0 bar. 10.9 is unchanged and the last value is -8.8 vs. -2.8, but without labels it's hard to figure out what those numbers mean. It might have something to do with fueling or engine load since the newer set of numbers have you driving with low engine rpm. The older set is idle and stopped.
