1 - 7 of 7 Posts
Been searching high and low for a speaker colour wiring diagram for a 2014 Jetta 1.8 TSI with the 6 speaker RCD310 cd/radio (Front Pillar Tweeters). I've got my component speakers coming in a few weeks and I'm worried that I won't be able to figure out the positive and negative wires of the harness once it arrives.
You can google it wiring diagrams or find someone with ElsaWin.
Or join and pay https://erwin.volkswagen.de/erwin/showHome.do for a day to save any diagrams as a PDF file.
I download a PDF file but I can't remember the link I had it from.
I searched the forum I had it from but nothing useful showed. I google it mk6 golf gti wiring components pdf and its the first one in the list.
MK6 Golf/GTI Wiring Diagrams & Component Locations
You don't need to join that forum you can still save the 1165 page PDF file.
I could have sworn I've posted the link in here before I did a search nothing shows. I searched TDI Wiki and nothing useful shows.
I will add the link to Fuse & Relay PDF Files so I know where it is on this site. ;)
Discussion Starter #4
Sorry about the first post mistake, I was starting to get worried because I've ordered the speakers and the installation is not exactly the most straight forward I've ever done. My plan is to shoot pictures of every step, then share on this forum.
I found that GTI wiring diagram yesterday but was not sure if it applied to my car. I stripped out the speaker diagrams pages from the pdf (see attachment).
A Golf VI (production end 2012) and a Jetta MY2014 should be two different things. If the speakers are sold fitting to your car, the set should include the harness.
I said post your log file not a PDF from the site as I have that already? That shows RCD 310 the same as mine.
VAG Error Code: 00873
Fault Location:
Bass Speaker: Rear Right (R17) - Electrical Fault in Circuit/Open Circuit/Short Circuit to Positive
Possible Cause:
Fuse(s).
Wiring/Connector(s) from/to Bass Speaker Rear Right (R17) faulty.
Check resistance of no output speaker and compare it with a speaker that works.
Speaker resistance can vary between 1, 2, 4 & 8 Ohms.
Possible Solutions:
Check/Replace Fuse(s).
Check Wiring and/or Connector(s) from/to Bass Speaker Rear Right (R17).
Perform Output Test.
Check/Replace Bass Speaker Rear Right (R17).
VAG Error Code: 00876
Fault Location:
Treble Speaker: Rear Left (R14) - Open Circuit/Short Circuit to Earth
Possible Cause:
Fuse(s).
Wiring/Connector(s).
Treble Speaker: Rear Left (R14).
Possible Solutions:
Check/Replace Treble Speaker: Rear Left (R14).
VAG Error Code: 00872
Fault Location:
Bass Speaker: Rear Left (R15) - Electrical Fault in Circuit/Open Circuit/Short Circuit to Positive
Possible Cause:
Fuse(s).
Wiring/Connector(s) from/to Bass Speaker: Rear Left (R15) faulty.
Possible Solutions:
Check Wiring and/or Connector(s) from/to Bass Speaker: Rear Left (R15).
Check/Replace Bass Speaker: Rear Left (R15).
Amplifier (R12) under driver seat
Discussion Starter #7
The speakers fit the car but I need to cut the harness to wire the crossover. The speakers I choose play very nice with low power factory stereos.
Infinity Reference REF-5020cx 5-1/4" component speaker system
1 - 7 of 7 Posts
