So I own a 2011 A3 TDI and it is not starting after I was pulling fuses out to check for blown out ones.
Initially, me and my dad were troubleshooting an electrical issue with the driver rear tail light (turn signal wasn't working) and we started checking fuses.
I went to the main fuse box and started pulling fuses to check them. I went all the way to the 40A fuses and when we tried to start the car it refuses to start. My dad thinks the fuel pump got shut off because I may have tripped some kind of safety thing when I started pulling fuses. Were thinking it was because of a main fuse. But were not certain.
Can anyone give some suggestions on what to do next? I have a feeling I royally screwed my car up and may have to take it to a dealer. Thanks in advance.
How long is a piece of string?
Re-check the fuses you pulled make sure they are in the correct slot if the car ran before.
I took it to a local mechanic and he said some of the fuses were in the wrong slot. So that was on my dumb ass for not putting them back properly. I'm taking a picture of the fuse box next time I have to mess with it BEFORE I mess with it.
There's a great possibility that you mistakenly missed some fuse slot. It happens often if you have unused slots there.
