I've been answering questions on another board where someone is trying to polish their headlights. Other people are telling them to just buy an adapter for a power drill. This is fine for the headlights, but why not get a polisher which will also work for the paint?
The reason why power drills aren't good is because if you leave it for too long in 1 spot or press too hard, they will heat up and damage the plastic or paint. Free-floating paint polishers stop if you press too hard, so it's foolproof...to a point. They are designed for detailing purposes, drills are designed for high torque.
Here are some pics of before and after using a dedicated paint polisher, it's worth it IMO. To show that it's not a camera trick, there are photos with and without flash, both before and after, from the same angles. from http://www.myturbodiesel.com/1000q_how_to/multi/polishing_paint.htm
Before, with flash
After, with flash
Before, without flash
After, without flash
Final result
This is from the detailing article here
Before, with flash
After, with flash
Final result
