Hi guys,
I have 2006 jetta 2.0 TDI and plan to replace my RCD300 with RNS510.
As I have read on my-gti.com (http://www.my-gti.com/1101/upgradin...210-rcd-310-rns-310-rcd-510-power-drain-issue) older (prior to 2008) VWs have battery drain issue due to older version of a CAN Gateway and updated version of CAN Gateway 1k0907530L or higher (currently mine is 1k0907530F) is required to overcome the battery drain issue.
Sincy my jetta is REMAPPED my question is wether the CAN Gateway change would require performing the remap process all over again, as new CAN Gateway have to be registered at the ECU.
Thanks
