Getting prepared to do my first TB replacement on 2002 ALH, 2004 BEW will be the following weekend unless I can get through both in 1 weekend. All of the TB kits I have run across come with the cam shaft seal. I am questioning how many of you are changing the cam shaft seal out of preventative maintenance (if it is not leaking) just because you are 95% of the way there during TB change. Is the seal known to be a leaker over time. Same question for the BEW cam shaft seal since my BEW will be next.
Thanks
Thanks
