Does anyone played with the cam degree in the Tdi ?
i usualy work with gas motor (BMw M10, Alfa's mostly) and often get adjustable cam gear to advance cam timing 2-4 degree to lower the rpm power band a litle...does this has the same effect on the Tdi ? the fact that the cam gear on the tdi is non-sloted would makes it very easy...
fwiw i know exactly how to set the cam using the lock tools,...
