Hi everyone. I have a 2013 TDI with 75k. Recently the timing belt snapped which seemed odd at that mileage. After taking everything apart the water pumped had seized and snapped a part of the pulley off. I put a new pump and belt on it and tried to start it and it ran for a few seconds and then shut off. So I figured some valves were bent. I recently just pulled the engine and took the head off to notice that all the valves are fine and found 4 rocker arms snapped in half. I read that there was some kind of lawsuit over the water pump issue they have. Does anyone have a set or at least 4 rocker arms and maybe lifters they can part with? I have 1 lifter I pulled that separated from its base. Thanks everyone.
Myturbodiesel moving on
Release Notes
This thread needs moving to the correct section if the new mod bjr72 does his job right as he is never here.
