you can guarantee it bent or damaged something.
go to www.tdiclub.com forums and send a PM to User Franko6
he rebuilds the TDI cylinder heads better than anyone out there.
He can set you up with a rebuilt head, new cam, new lifters, and a complete timing belt system for a good price.
Where in Florida are you?
Well Autodata say: ;)
Check For Engine Damage
CAUTION: This engine has been identified as an INTERFERENCE engine in which the possibility of valve-to-piston damage in the event of a timing belt failure is MOST LIKELY to occur. A compression check of all cylinders should be performed before removing the cylinder head(s).
