So after doing the camshaft on my 2006 BRM, I started having turbo/low power issues. Upon investigation I found that there was a vacuum leak at the tandem pump outlet nipple. Turns out I must have ripped the rubber grommet/seal/nipple (whatever the name for it is) that goes on the tandem pump nipple when I reinstalled the brake booster vacuum line. I siliconed it up the best I could for the interim, but I really need to find a replacement. After several hours of fierce googling I have come up with nothing. No Name, parts diagram, part number, nothing. Even the replacement vacuum booster lines do not appear to come with it. Does anybody know the name/part number of this and/or where I can source a replacement. If not, does anybody have a good fix/hack for connecting the brake booster line to the tandem pump. Since the connector is plastic I cant simply use a hose clamp.
Post a picture?
