i have a 2006 jetta BRM. stock turbo, no tune, has a fresh cam in it. I’ve done the zip tie mod on the turbo to fix low rpm smoke. Since I’ve had it, I’ve noticed on the highway on flat ground, I could hear the turbo spool up faster and then a very slight lunge forward with the car as the turbo went quiet. This would repeat every 5-10 seconds, but only sometimes.
I’ve just recently got set up with VCDS, and I have discovered that the boost while I’m at cruising speed is always above the specified boost. For example, if I’m cruising at 70, specified boost might be 0.4 bar, but I’m seeing the actual boost fluctuate between 0.6 bar all the way up to 1.3 bar. The weird part is, under higher load, such as pulling up a hill, the actual boost matches specified exactly! No issues there, only under medium load. Obviously this is hard on my turbo and my engine, pushing so much boost all the time, especially because most of my miles are highway miles. So, what’s the best solution here.
Do I buy a PD140 without a smart actuator and run it? I’ve read they run fine with a stock tune but just throw a check engine light, is this true? I don’t mind dealing with just a CEL until I can get it tuned.
Do I get a new n75 and see if that fixes the issue?
Do I check wiring and see if there’s an issue there?
I can’t imagine this stock turbo will last too long running those kinds of boost levels so often and for so long.
Thanks for any input!! It’s much appreciated.
