I am replacing the camshaft on a 06' Jetta TDI. I was told to do the head gasket at the same time, is this true? Appreciate any advise...
No, take a look at the pictorial. You remove the rocker bolts not the head bolts. You should not remove the head bolts to change the camshaft. The factory service manual also does not recommend changing the head gasket.Sorry I should have been more specific I was told that when removing the camshaft the bolts go through the cylinder head and into the block so there is a chance of a head gasket leak just wondering if this is true I cant see a problem but just thought if someone had done the job before they could offer me some advice
