I don't have the part numbers for the 2010 but for the 2009 models, the front and rear VW GTI caliper and rotors part numbers are the same as the Audi A3 gas model. I assume the Audi A3 TDI gets the same rotors as the Audi a3. 312mm x 25mm in the front.
The rears are also the same- 286mm x 12mm rear rotors.
Thanks for the tip, I will add it to the Audi A3 checklist. Both cars are FWD but the A3 is automatic and 4 door only so it weighs about 255 lbs more than the Golf TDI automatic. According to VW's site, the golf TDI (doesn't say 2 or 4 door) weighs 3,041 with DSG. I assume that's the 2 door weight because the picture above the specs on VW's site shows a 2 door. According to Audi's site, the A3 gasoline weighs about 3296, no spec is given for the A3 TDI.
