1 - 9 of 9 Posts
They are 1 use only
g60 flywheel: 22 ft lbs, stage 1
44 ft lbs, stage 2
final torque is an additional 1/4 turn.
stock pressure plate is 15 ft lbs, I suggest tightening them diagonally and in stages until they are hand tight. Then to 15 ft lbs
use a tiny drop of locktite on the bolts and note that it's ft lbs, not Nm.
Use red locktite too, it's the stronger type.
The pressure plate bolts will be hand tight pretty quickly,I suggest after hand tight, 1 turn at a time until they are wrench tight, then to final torque. The reason why is because the pressure plate springs are working against the bolts.
1 - 9 of 9 Posts
