Thanks Chitty,
a) Yes - I don't have a H cluster
b) Sorry, I meant the option in the module to allow for a single press of the remote lock button to lock the doors and simultaneously raise the windows is not there. I have to hold down the lock button for like 3 seconds on my remote to raise the windows. Can't find any posts where users experience this problem setting it VCDS. From memory the option is supposed to be in CECM long coding Byte 6, my Byte 6 is very different to the screen shots I have seen.
c) I turn on the feature in the control module to beep the horn on unlock but it has no effect. It is not an option in the MFD. I suspect this is a feature dependent on the factory Alarm system being fitted. Mine only has the immobilizer
The other thing that doesn't work is the option to increase the comfort turn blinks from 3 to 4 or 5. The option is there in the control module but has no effect when you change the value?
I have read a post recently that suggests that if you make the change in VCDS and the use the MFD to change the Lights setting to Factory settings it then it works? I'll post back if this procedure actually works.
Do you or anybody know what the "star" button does in the roof console. I have programmed the other 2 buttons to dial numbers I have assigned but would like to assign this button to do something useful if possible. I suspect it has something to do with activating something on a higher level radio system than I have which is RDS310 (stock radio in Australia)
Thanks heaps for your info.
Brett.
