1 - 7 of 7 Posts
Good Afternoon Gentlemen
I have a 2006 VW Jetta TDI 1.9 BRM with the DSG automatic trans. I am up to date with preventative maintenance on the vehicle even with 259k on the original engine and trans. My question for you gentlemen, is this model capable of advancement for better fuel mileage such as 60-70mpg with added powers? Is there a recommendation for a certain tune I could possibly use or changing out certain mechanical components, I am definitely interested in your opinions. Thank you very much again.
GySgt Filipi
United States Marine Corps
Welcome to the forum.
This is a new forum layout which is owned by a company last year that doesn't give a dam with loads of bugs which have been reported in the new thread. There is no TDI Wiki at the moment or original similes. It doesn't show the car spec/location.
  • Like
Reactions: Skanderbeg35
To answer your question, have never seen anything where someone made reliable claims of fuel economy beyond low 50s on continual highway driving. Much beyond that and the consensus is the car is running too lean to be healthy.
A good start is a performance cam, slightly bigger injectors, deleting unnecessary parts and adding a good tune. You would be surprised where that gets you. Probably high 50s
  • Like
Discussion Starter #5
thank you for the response sir, i will adjust fire on my info, thanks again
Discussion Starter #6
I’ll definitely look into those items sir, I was reading this forum about putting a propane secondary system, it sounds dangerous but wanted to see if this was legit system. I also looked into the bio diesel system the offer for this car, I know though that it has some issues due to the vegetable oil base and cleanliness of the boiling down the product before usage as a fuel. I just wanted to see what you gentlemen though about either one of those systems. I’ve already been looking in Kerma Diesel for those parts you mentioned sir, thank you.
Some heavily modded diesels use propane injection as a supplement boost in power, similar to a NOS effect on a Gas motor. I would make sure your motor has head studs before you try that. Or they run full conversion on propane or LNG with good results. Vegi oil on these cars seem to be problematic over the long run clogging piston rings and such, maybe if u ran 50/50 diesel and vegi oil it would be ok. Lots of work refining the oil in your garage, seems like too much work, until fuel prices get higher. Happy modding....
1 - 7 of 7 Posts
