Best option for block heater?
11371 Views 8 Replies 8 Participants Last post by  Russ
A stick on heater or freezeplug item?
1 - 9 of 9 Posts
What car is this for your profile doesn't say? The frostheater coolant heater is a pretty good one. It uses an electric heater to heat the engine coolant. This way it heats the whole engine.
There is a good chance your engine doesn't even have frost plugs. The stick on ones are OK as long has you don't have to actually heat anything - 250 watts max. I put a Frostheater in my '05 Passat. http://www.frostheater.com/
The stick on ones can fall off and cause a fire. The coolant heaters are the best because they give instant or almost instant heat in the winter. VW has an OEM one and frostheater makes aftermartket ones.
Since your profile says looking, I assume you want a new car. I saw a similar post elsewhere for OEM coolant heater with different info, here is some more info:
VW# 1km 198 062 is the OEM retrofit coolant heater kit for manual transmission 2009 Jettas. I assume that it will probably work on 2010 Golfs and Jettas. VW# 1km 198 062 a is the kit for DSG transmission. I am told that they are interchangeable but there may be a small difference in fitment. It appears that the exact part number is a European special order part which costs about $450! An alternative may be the part for older cars 2006 Jetta, VW# Jnv 198 006 a. It's a Calix 550w heater. I don't know if it'll fit the new 2009-2010 TDI.
The frostheater is about twice as powerful= less warm up time.
It would take forever for a freezeplug or oil dipstick heater that it would basically do nothing. Frostheater is cheaper but it's bigger and faster but doesn't fit like the OEM does. VW sells a 3 prong outlet that fits into the front grille.
Frost Heater
Just orderd a frost heater from kerma was hoping for some install tips with some pick's would be helpful Thank's
1 - 9 of 9 Posts
