So after alot of work to my wife's 2002 Golf 1.9 TDI regarding fuel issues and low power,I'm at whits end and had enough of this thing.
So far I have :
Replaced MAF
Cleaned EGR and Intake
Cleaned N75 Valve
Vacuum Tested and replaced all lines
New FTS
New FF
Diesel Purge
New SMOG .216 nozzles
Hammer Mod
the list goes on
I used to get QA Upper and Lower Limit faults, CEL's and this is what's leading me to believe it's the pump. After doing the nozzles the car has more power and seems to be better, but when pushe it too far, it bogs down like its starving for fuel?
Now none of the codes come back that indicate the QA, but that doesn't rule it out, it just means the pump is not timed right.
Scanned the car and came up no CEL's.
MAF reads good and REQ vs ACT are in the same range at different rpms.
IQ is set at 3.2 mg/str, it has jumped around to 0 and 8 by itself at idle
Timing is at 48, a little advanced but in spec at NOT.
Wife called me after work and said the car was harder to start,chugging badly and blowing white smoke?
Really not lovin this car right now.
So far I have :
Replaced MAF
Cleaned N75 Valve
New FTS
New FF
Diesel Purge
Hammer Mod
the list goes on
