1 - 6 of 6 Posts
VCDS showing 4 faults. Auxillary heater element. Part #1KO963235E. Drivers electric window motor. Drivers door mirror blinker. Locking module on drivers door.
All these are working. How do I find out what is causing the faults.
VAG Error Code: 16725/000833/6039/4113
EOBD II Error Code: P0341
Fault Location:
Camshaft Position (Hall) Sensor (G40) - Implausible Signal
Possible Cause:
Wiring/Connector(s).
Camshaft Position (Hall) Sensor (G40) faulty.
Timing misaligned.
Possible Solutions:
Check/Replace all faulty Wiring/Connector(s)..
Check Camshaft Position (Hall) Sensor (G40).
Check Timing.
Tech Notes:
Sometimes and in some models, low battery voltage or a weak starter can trigger a Camshaft Position Sensor code.
When is the code detected?:
The camshaft position sensor signal sent to the Engine Control Module (ECM) during the first few seconds of engine cranking is out of range.
Description:
The Camshaft Position (Hall) Sensor is an electronic device used in an engine to record the rate at which the camshaft is spinning. This information is used by the Engine Control Module (ECM) to control ignition and fuel injection. The camshaft position sensor senses the retraction of camshaft (intake) to identify a particular cylinder. The Camshaft Position (Hall) Sensor senses the piston position. The sensor system consists of a rotating part, typically a disc, as well as a static part, the actual sensor. When the engine is running, the high and low parts of the teeth cause the gap with the sensor to change. The changing gap causes the magnetic field near the sensor to change. The change in the magnetic field cause the voltage from the sensor to change. When the Crankshaft Position Sensor system becomes inoperative, the camshaft position sensor provides various controls of engine parts instead, utilizing timing of cylinder identification signals.
When the Crankshaft Position Sensor system becomes inoperative, the Camshaft Position (Hall) Sensor provides various controls of engine parts instead, utilizing timing of cylinder identification signals.
VAG Error Code: 02394
Fault Location:
Parking Light: Left Front (M1) - Electrical Fault in Circuit/Open Circuit/Short Circuit to Earth/Positive/Defective
Possible Cause:
Parking Light: Left Front (M1) not working.
Fuse(s).
Parking Light: Left Front (M1) faulty.
Possible Solutions:
Check/Replace Fuse(s).
Check Parking Light: Left Front (M1).
Perform Output Test (Light Switch OFF).
VAG Error Code: 00932
Fault Location:
Electric Window Motor: Drivers Side (V147) - No or Incorrect Basic Setting/Adaptation/Adjustment
Possible Cause:
Window Automatic Run not working.
Pinch Protection limited.
Automatic Run & Pinch Protection not adapted.
Incorrect Window Motor/Door control module installed.
Possible Solutions:
Adapt Automatic Run & Pinch Protection (see Special Notes).
Verify the correct Window Motor(s)/Door control module(s) are installed.
Special Notes:
Pinch Protection Adaptation.
Make sure the window in question is completely closed.
Use the driver door window buttons to operate the window(s).
Roll down the window and keep holding the button down for 2 additional seconds after the window is already fully opened.
Roll up the window and keep holding the button up for 2 additional seconds after the window is already fully closed.
Now test the window automatic.
VAG Error Code: 00928
Fault Location:
Locking Module for Central Locking: Front Drivers Side (F220) - Implausible Signal
Possible Cause:
Door Locks not working properly.
Wiring/Connector(s) from/to Locking Module for Central Locking: Front Driver Side (F220) faulty.
Voltage Supply for Locking Module for Central Locking: Front Driver Side (F220) faulty.
Door Lock Mechanics are stiff/partially seized.
Possible Solutions:
Check/Replace Wiring/Connector(s) from/to Locking Module for Central Locking: Front Driver Side (F220).
Check voltage supply to driver's door control unit or to door main connector (lower left footwell).
Check Door Lock Mechanics/Operation.
Check Locking Module for Central Locking: Front Driver Side (F220).
VAG Error Code: 00120
Fault Location:
Outside Warning Light/Door Exit Light: Drivers Side - Electrical Fault in Circuit
Possible Cause:
Wiring and/or Connector(s) from/to Outside Warning Light/Door Exit Light Driver Side faulty.
Possible Solutions:
Check Wiring and/or Connector(s) from/to Outside Warning Light/Door Exit Light Driver Side.
Check/Replace Outside Warning Light/Door Exit Light Driver Side.
Perform Output Test.
VAG Error Code: 00109
Fault Location:
Turn Signal Lamp: Left Mirror (L131) - Electrical Fault in Circuit
Possible Cause:
Voltage Supply for Left Mirror, Turn Signal Lamp (L131) faulty.
Possible Solutions:
Check Voltage Supply for Left Mirror, Turn Signal Lamp (L131).
Check Left Mirror, Turn Signal Lamp (L131) Operation.
Replace Turn Signal Lamp: Left Mirror (L131) with new unit as LED bulbs are not a replacement item.
LED bulbs:
ElsaWin Quote:
On some vehicles, the illumination is not provided by a light bulb, but by an LED (light-emitting diode), depending on the equipment level. This LED is permanently attached to the retaining sleeve and cannot be renewed separately.
Retaining sleeves with a light bulb are available in different versions. On the one version, the light bulb can be replaced separately; on the other version, the light bulb cannot be replaced separately. In this case, the bulb carrier has to be replaced together with the light bulb.
VAG Error Code: 00944
Fault Location:
Heated Exterior Mirror: Passenger Side (Z5) - Electrical Fault in Circuit
Possible Cause:
Mirror Heating doesn't work.
Mirror heater not installed.
Heated Exterior Mirror: Passenger Side (Z5) faulty.
Possible Solutions:
Check Wiring/Connectors from/to Heated Exterior Mirror Passenger Side (Z5)
Check/Replace Heated Exterior Mirror: Passenger Side (Z5).
Special Notes:
Sometimes the switch button for the mirror has 'L', 'R' and '0'. When switched on '0' the mirror heating is on!
VAG Error Code: 00361
Fault Location:
Heater Element for Auxiliary Heater (Z35) - Faulty/Defective
Possible Cause:
Auxiliary Heater not working.
Fault Code(s) cannot be cleared.
Heater Element for Auxiliary Heater (Z35) faulty.
Possible Solutions:
Check/Replace Heater Element for Auxiliary Heater (Z35).
Special Notes:
When found in Auxiliary Heater, this Fault Code often cannot be cleared. Usually this Code implies that the Heater Element (Z35) houses the Control Module this Fault Code is stored in, therefore the Heater Element may need to be replaced to fix this.
Discussion Starter #5
Thank you very much for reading the codes and suggesting the fixes. I have replaced the cam sensor. Now ok. I have replaced the parking lamp. Now ok. I did at one time replace the drivers door electric window master switch control unit only because the black rubber material from the factory worn off and I found a better looking one in a junk yard and put it in my car. The windows work fine. But you know maybe that is why the passenger mirror heater is now not showing that it works. It did before. I can live with the auxiliary heater code. It does warm up right away when you drive it. I will use the VCDS and measure blocks. I have never used this feature before. I don't want to do something wrong and have the car not run. Any special blocks not to touch. Thanks again.
Do you have the correct fuse and reply layout for 2006 Jetta?
Fuse SA6 100A Auxiliary Heater Element (Z35)
F30 20A Auxiliary Heater Control Module (J364)
F11 20A Auxiliary Heater Control Module (J364)
F25 20A Auxiliary Heater Operation Relay (J485)
Fuse & Relay PDF Files
1 - 6 of 6 Posts
