I have been struggeling with my 1999 A6 1.9 TDI 81kw. I have replaced starter and G28 sensor, fuel return valve and glow plugs. VCDS doesnt show any error codes. Timing is in good range. Sometimes it starts normal and sometimes like in the video below.
It does start but it sounds rough.
Manufacturer: Audi, Date(s) Used: 04/1997-04/2001, Model: Audi A6/Avant, Engine Code: AFN, 81Kw, 110PS, 1.9 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection (TDI) Timing belt
