1 - 6 of 6 Posts
Hello DieselHeads
I bought a used A4 2.0TDI 16v BRE and i notice that the engine is wobbly when the engine has reached operation temperature 90c. When the engine is cold then its normal in standing still but when 90C then wobbles Other side effects are: driving 6th gear 90-100km/h cruise control and it wobbles on a straight or going down a slow hill. Going up the hill the everything normal. Yesterday changed the fuel filter but nothing. Any ideas what to look under the hood/VCDS to diagnose the problem
Sorry when my english is bad.
No clunk or clonk. When i remember, then one mount was covered from the bottom in red liquit(right side). Does it really affecteds so much?
Discussion Starter #4 (Edited)
UPDATE: I did a log on my car and the rews drop from idle 882 to 861 for some reason and goes back up again. Here is the log file http://www.upload.ee/files/5488193/Audi_BRE.xlsx.html
Because its my first log and this problem is very disruptive and i dont know here to look solution, i added as much info as i could. Any ideas???
As said check engine and gearbox mountings.
There are errors codes for mounting.
1 - 6 of 6 Posts
