audi a4 awx less powerful
15238 Views 23 Replies 4 Participants Last post by  stig
hello i am new to the forum and i have problem with my audi a4 b6 1.9 tdi awx it have 30% less power than it should have. I checked turbo and the variable geometry no problem, with maf disconnected its less powerful. On diagnostic its not showing errors, no smoke from the exaust engine starts almost wihout cranking no weird sounds from the engine, what can be the problem ....sorry for my english im from macedonia
21 - 24 of 24 Posts
hi i'm back again, on my audi i've changed camshaft lifters and followers it's all new but this is a big dissapointment to me the car is the same again no change in the performance old cam was damaged on two ehaust lobes on cylinder 2 and 3 they were worn 2mm and the lifers were damaged, what can be the cause on this problem this car it's making me crazy lot of work and money but no change in performance please give me some opinion im stuck without any ideas.......................... :confused:
I certainly sympathize with you here, but am out of ideas. Exhaust or intake clogging? Start from the beginning and double check?
on vcds in channel 13 (idle speed smooth runing control) i noticed higher value at cyl #4 than other three cylinders the value is sometimes around 1.84 at coolant temperature 85 degrees and if coolant is around 70 degrees the alue on cyl #4 is around 2.33 i wonder what this means ?? other three cylinders are around zero.
Chitty im waithing for your oppinion what do you think could my problem with loss of power be related with faulty injector? ........the car has no power below 2000rpm
21 - 24 of 24 Posts
