Where in the UK are you?
Audi A3 (03-) 2,0D TDI PD 2003-08 Engine code: BKD
Cylinder head Renew bolts: Yes
Stage 1: Tighten: 40 Nm
Stage 2: Tighten: 60 Nm
Stage 3: Tighten: 90°
Stage 4: Tighten: 90°
Camshaft sprocket/gear
Sprocket bolts: 25Nm
Centre bolt: 100Nm
Camshaft carrier/cap
Centre bolt: 100Nm
Camshaft/rocker cover: 10Nm
Rocker shaft: 20 Nm+90°, Use new bolts.
Timing Belt:
Tighten tensioner pulley nut. Tightening torque: 20 Nm + 45°
Tighten bolts of each camshaft sprocket. Tightening torque: 25 Nm.
Tighten camshaft sprocket centre bolts. Tightening torque: 25 Nm.
Tighten bolts of each camshaft sprocket bolts. Tightening torque: 25 Nm.
Tighten RH engine mounting bracket bolts. Tightening torque: 45 Nm + 90°. Use new bolts.
Tighten crankshaft pulley bolts. Tightening torque: 10 Nm + 90°. Use new bolts.
Engine mounting bolts Fig. 24. Tightening torque: 50 Nm.
Engine mounting bolts Fig. 25. Tightening torque: 20 Nm + 90°. Use new bolts.
Engine mounting bolts Fig. 26. Tightening torque: 60 Nm + 90°. Use new bolts.
You may need to see the diagram for Fig numbers though engine mountings aren't that critical?
Tighten bolt securing lower torque reaction link to subframe. Tightening torque: 100 Nm + 90°. Use new bolt.
