Welcome to the forum Jason. welcometomyturbodies
VAG Error Code: 17978
EOBD II Error Code: P1570
Fault Location:
Engine control module (ECM) - immobilizer active
Possible Cause:
Incorrect/damaged key.
Incorrectly coded.
Engine control module (ECM)/Immobilizer replacement without coding.
Wiring.
Immobilizer defective.
EOBD II Error Code: 01176
Fault Location:
Key: Signal too Low
Possible Cause:
Malfunction Indicator Light (MIL) ON.
Immobilizer
Wiring and/or Connector(s) from/to Immobilizer Reader Coil faulty.
Immobilizer Transponder in Key faulty OR incorrect Transponder in Key.
Remote Control:
Remote Control Battery low.
Remote Control faulty OR incorrect Remote Control used.
Possible Solutions:
Immobilizer
Check Wiring and/or Connector(s) from/to Immobilizer Reader Coil.
Check Key Immobilizer Transponder Status.
See Measuring Value Blocks (MVB).
Check/Renew Immobilizer Key Matching.
Check/Replace Key.
Remote Control
Check/Replace Remote Control Battery.
Check/Replace Remote Control.
Special Notes:
This Fault Code can be stored in due to Remote Control or Immobilizer Problems. On most Models these systems are separate and should therefore also be diagnosed separately.
In case of Engine Starting Issues please make sure that you are really experiencing an Immobilizer related Problem! On most models using conventional keys, the Engine will still start but cut out after 1-3 Seconds if an Immobilizer related Problem is the cause. On models using Kessy Systems and Electronic Keys, most systems in the car won't power up at all if if an Immobilizer related Problem is the cause. If you are NOT experiencing this behavior (e.g. Instrument Cluster powers up, and engine cranks but doesn't fire at all or engine won't crank) this is likely NOT Immobilizer related.
When found in Audi A3 (8L), Audi A4 (8D), Audi A6 (4B) or Audi A8 (4D), check Wiring from Immobilizer Control Module to Immobilizer Reader Coil. A known issue would be the Length of the Wiring, an optimized Replacement Part may be available 8D0-972-275).
May be stored in Combination with 17656/P1248/004680 - Engine Start Blocked by Immobilizer in Engine Control Module.
As taken from my
http://www.myturbodiesel.com/forum/f9/free-eobd-ii-error-codes-software-2919/
