A few wks ago i had a battery drain issue that i traced to the radio. I put a rocker toggle switch on the power supply wire and solved that. Now my alarm has gone off 3 times in the last 24 hrs while sitting in my garage. Could this be a driver door wiring harnes problem? Any help would be appreciated.
just checked wiring harness. looks good. could i need to replace door control module? need help this is driving me crazy
Probably not, they don't just fail. Check the grounds in the engine bay, there are some under the battery IIRC. There is something going on with your car.
