I have replaced the ambient air temperature sensor on my 2010 Jetta TDI. I put the new sensor in and then parked the car. Did not drive it or leave the car running for a time to let the sensor reset itself. Is there a way to reset it using VCDS?
I don't think there is a reset with VCDS.
Keith,
I have posted on this forum before. It was before the site was upgraded so I didn't think I needed to do it again. I did do a search and didn't see the answer I was looking for, hence the reason I created my post. I should have also mentioned that it has twice showed a temp of -35 and then started to level off toward the actual temperature but it hasn't made it to the point where it actually showed the true temperature. Was trying to avoid pulling the front apart again to get to the sensor to unplug it and then plug it back in again to reset it.
Well your post count shows 2 in this thread.
