alh vacuum pump
2237 Views 3 Replies 3 Participants Last post by  darren
hello
the vacuum pump on alh engine has a pipe that moving causing the
pump to loose vacuum what do you think if i weld the pipe can it
fix the pump ?
The rubber hose? I would just put a hose clamp on it? Otherwise I think you should be OK.
not the rubber hose i mean the aluminium hose on a new pump
it's steady on my pump it's shaking
You could clean it and put some exoxy around it. Maybe even silicone?
