1/2 a tooth
I should have explained this better, but before I removed the old timing belt, With the crank at TDC the camshaft lock bar would not engage into the slot in the end of the cam. The cam was advanced with respect to the crank. I thought that it may have just been 1 tooth off- due to an old worn out belt maybe skipping a tooth?? (Dont really know) but I moved the camshaft sprocket back a tooth to see if this helped line things up, after tensioning everything the camshaft lock bar still would not engage at TDC This time it was retarded by about the same amount. So this tells me that either the cam sprocket/pully was put on in the wrong position or it has spun on the shaft.
Any way this is not a problem, now as I have pulled it off, realigned and Torqed to 40 ft-lbs as per 1000q Timing belt write up part 2 (Awesome Article Great Job!!)
The car runs fine, actually sounds better than it did before I did the Timing Belt. I just need to find a Vag-Com to Fine Tune It.
