Hello everyone! I´ve got an 01 alh golf that has been having quite a few issues. Today, I´m wanting to figure out why it is overboosting. I´ve got good movement in the actuator arm(starts at 5 and will stop at 18 according to my mighty vac). It will still overboost but only for half of a 1 hour drive. When it doesn't overboost, Ill see about 24 psi and then itll even out to 15 and my exhaust note gets noticeably deeper. Any other time, its hard to not build almost 5-10psi just while cruising in 5th going 75 and all you can hear is turbo noises.. anyone have any ideas?
Normal cruising while overboosting will put me at about 10 psi maintaining 60, but when whatever happens to make it not overboost will having me cruising at 0psi, but also feels as if it builds boost normally as it should when I get on it..
