Did you go to the dealer? What did they say? This is a pretty rare problem.
Yes I dropped it off at the dealer this morning. They told me the connectors were loose or became loose for whatever reason. But those are under the driver seat and thus it wasn't a quick fix as they needed to remove the seats to get at the connectors (I don't know why they are located down there). Hopefully this is an isolated occurance. I'm going to pick up the car now from the dealer.
I had the airbag light go off under warranty in the center seat of my A4 Avant every time someone used it (which was only once every year or so). First they replaced the ignition module in the seatbelt pre-tensioner, then the seatbelt itself, then found out it was just a loose connection.
