After installing a used head from what I was told a good running engine. Car ran fine for about 15 min. Then sporadic rough idle. I thought injector issue. So ran engine with valve cover off. I saw quite amount of oil almost shooting up from #10 headbolt. Since oil looks under pressure. I don't feel it is from blow by into head bolt "hole".
Could the leak be from the cam cap. Or cam journal. Sorry. I haven't seen actual Male for the metal block that supports the cam and its bearing.
So any ideas it this is due to faulty head gasket, head bolt, or cam hardware.
I think I found the issue. There is a small cap on the rocker shaft tubes on the inside edges. There is about an half inch gap between the 2 assemblies. It looks like a 1.4 inch silver "tube" is between the 2 tubes. I think one of these popped out and is lodges between the 2 tubes. Can I use the tube - rocker assembly from the older head onto the newer head. Or do I need to purchase a new tube assembly.
Discussion Starter #4
Is the guy in the middle of the 2 rocker tube assembly's one of the end caps stuck there. If so. This just happened and I caught it before excessive camshaft assembly wear
