Charged the battery a bit and after connecting all the hoses, started the TDI (2005 jetta) today and it ran well for a few minutes twice, but then it wouldn't rev and a lot of smoke started coming out. In fact, if I didn't turn it off it probably would have stalled. My OBD said, the P101 code or the mass air flow.
I should give some detail. The car has been sitting a while, but I don't think there is bad diesel/stale.
Maybe I am missing a wire connection, and I can take the MAF apart. That wont be too bad.
I tried to clean all the oil/soot in the EGR, and manifold, and I wonder if I damaged something.
I should probably have a VAG com check, but I can't drive this any where.
Between this, smashing my finger taking the wife's trans drain bolt out, my dog's 750 vet bill, 500+ for the cam, and winter fully here and I can only be outside on the car ever so often. It's been awesome. Ugg.
Thanks in advance.
There is a number missing of that P101 EODB II error code
OBD scanner is no good for posting error codes as they give wrong codes and false results.
