I am going to add a lift pump to my TDI here shortly. I was going to go with some standard aftermarket pump that puts out 10-15 psi. I was thinking about using the headlight circuit that turns on when the ignition is on...because I don't feel like cutting into the injection pump harness. I could always run a new wire off the fuse box with either a switch.
Just thinking out loud. Any advice is appreciated.
