Here's the process I did:
1. Move (cold) car from driveway to garage (it's raining). Only had it running a few moments.
2. Top off oil (a little low) and washer fluid
3. Remove lower line to the N75 solenoid in order to attach vacuum pump to
4. Adjusted VNT - lengthened rod, as it was hitting the stop at 14-15 in-mg instead of 18ish.
5. Replaced vacuum hose on N75
Doesn't seem like that would cause any problems starting? Coincidence? Did I knock something loose/broke? The glow plug light goes off after a second as normal, and the car cranks hard, but never fires. The anti-shudder valve is open and moves freely when adjusted by hand. What'd I do?!?!? Never had any problems starting before this.
Probably unrelated, but last night I hooked up VAG-COM the first time and ran through the diagnostic tests with the car running (didn't realize there was no option to select which test you want and it just does them when you click Start). But even still, I moved the car into the garage today (long after that).
Is there any functions in VAG-COM that would cause the car to refuse to start? Like immobilizer related (although I have only been into the Engine module so far)?
