This is a follow up on a post at audiworld:
Cliffs: the dealer forgot to top off a Q7 TDI adblue tank and the low level light came on. Dealer showed him a TSB that said only the dealer can get the adblue tank to know it has been filled up. The real problem is that if the adblue tank thinks it's empty it will cause a no start condition due to not meeting emissions. (Technically I think it'll let you do 1 start after the final warning).
The post and the follow up posts:
For the moment, the preferred method of DIY refueling refueling is with a bottle. You can see more at http://www.youtube.com/watch?v=ezUPuUHGa04
With this method, as you can imagine such a sensor is not necessary. However, there is a sensor on board that will detect that another (different from AdBlue) liquid has been put into the tank. If refueling with an incorrect liquid is performed and the senor detects it, the vehicle will either not be able to start or will have restricted power (depending on manufacturer).
Full refueling of the AdBlue tank is for the moment only practical at the dealership. This is something that all manufacturers want to change. It is simply not acceptable that cars are being developed with increasingly longer service intervals and that customers must return to the dealership for a refill. Also, the overheads (and mechanics hourly rates) at a modern dealership mean that they must charge a high price for the AdBlue. The strategy for the manufacturer to increase sales of SCR vehicles means that they want the price of AdBlue to remain relatively cheap, compared to the diesel price.
In the future, when the number of cars requiring AdBlue increases, all car manufacturers would prefer that their customers refuel at a regular gas station.
When the new European emission legislation kicks in, all diesel powered cars will need to have SCR. It is simply not financially viable for Audi (and all other car manufacturers) to have two separate engine development programs. Whether or not the Audi A4 TDI is available with SCR, is a question that you need to address to your dealership.
chrisr said:Got a Q7 TDI, and at the 5k service the dealership didn't fill it up with AdBlue. Result was that
around 11k miles it gave the warning of 1500 miles left. Called to see if I could just buy
the AdBlue and fill it myself. (had to speak to 3 different people before I got someone who knew what that was)
The dealership ended up filling it, but in the process they gave me a "Technical Service Bulletin" which seems to address a problem of the "Refill AdBlue" message show despite adequate level.
The solution is to use a diagnostic computer to run a function called "Adapting reducing agent tank adaption values". The bulletin indicates that this is normal procedure when re-filling with AdBlue!?
So does this mean that one really can't re-fill AdBlue at home? I understand that physically I can add it, but if the sensor has to be reset, it does me now good as the engine will not restart once it runs out.
More :alan cardew said:Hi ChrisR,
I expect that the user friendliness of AdBlue (in the USA DEF - Diesel Exhaust Fluid) will be a major subject of discussion in the future.
I am the Managing Director of an AdBlue refuelling equipment supplier to the auto and truck industry. One of the major early complaints with AdBlue will be the ease of refuelling by trucks, compared to passenger car owners. This is a difficult question to answer, but is based on the comparative sizes of tanks and the refuelling flow rates in the two vehicles.
It will not be for the forseeable future be possible to refuell AdBlue in the same way that you can refuell gas in your car. We are working together with Audi on possible solutions, but the amount that each vechile needs is small in comparasion to diesel or gasoline cars and that because of the aggressive chemical nature of AdBlue regular pumps are not economically feasable right now.
Your problem relates to a simple safety mechanism. Audi has given assurances that this technology will perfom as designed for the vehicle's lifetime. Without proper safeguards, it would be possible to pour tap water in the tank and nobody would be the wiser. Naturally the exhaust emmissions would be enormous and the vehicle's AdBlue onboard system would be destroyed. The legislators as well as the car manufacturers would prefer this not to happen, therefore controls have been put in place for unscrupulous drivers.
The environmental and economical benefits far outweigh any negatives and buyers of cars fitted out for AdBlue should not be discouraged from purchasing this technology.
I hope that you have great pleasure in your Q7 and can assure you that you have made a wise choice.
