I'm hoping you guys would be able to help.
Due to living in New Zealand aftermarket suspension is rather costly.
None the less I have managed to find some ABT Coil-over suspension. the problem is the car it came out of is just a 2.0FSI not a 2.0TFSI.
Now I have been trying to find info from ABT if they make a GTI specific or not.
At present the only thing I can confirm is they make a R32 specific kit (which is understandable)
but no concrete info about the the other.
so if anyone can shed some light that would be greatly appreciated.
Thanks
The mk5-mk6 suspensions are interchangeable. I'm not sure on this but the coil over kit should fit any mk5-mk6. I don't know why the R32 would be different other than the rear drive suspension.
Chittychitt
Chittychittybangbang - I know R32 would be specific as pointed out due to 4WD, in addition to the additional weight of the R32 engine.
Now I just have to figure out about the 50mm or 55mm strut size.
Thanks for the reply, out of 5 forums. I have received any replies.
