Hi all,
I have a 2002 Golf TDI that has been acting a little twitchy. Sometime this winter, I started occasionally having my ABS and brake lights flash, but with no symptoms of either malfunctioning. It wouldn't happen every time I started the car, seemed to mostly be on the coldest days.
Some weeks later my engine light came on - code was for glow plugs, which I replaced last week. Since replacing the plugs, the ABS/brake light flash has been consistent for the first 5 minutes or so after every cold start. I drive 40+ miles one way for work, so I see that the lights stop and don't come back on. For what it's worth, this now happens on every cold start (regardless of outside temperature), but does not seem to happen if I restart once the car is warm.
Using VCDS I get an ABS code
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
I was thinking I need to replace an ABS sensor, but the two electrical problems seem related to my uninformed mind - especially since the ABS issue seems to stop when the engine is warm enough for the glow plugs to stop working.
I checked the fuse box a while back and didn't notice anything obviously wrong, but could still be an issue. If it is a ABS wheel sensor (front) how do figure out left or right?
Thoughts on how to proceed?
Thanks
Thanks
