1 - 7 of 7 Posts
hi i have petrol a6 and want to get a diesel passat and transplant the diesel engine into it. going to do it no matter what. thing i want to know is, the a6 is automatic box and what would happen if you only changed the engines would the auto box bolt on to the diesel. And what sort of mods ecu wise am i looking at do i take the ecu out of the doner car with wiring harness. and will the torque converter of the 1.8 fit the 1.9 crank
That could save a lot of hassle. I wouldn't fancy trying to wire in the ecu etc.:eek I would've thought the gearbox fitting would be fine but I'd imagine the ratios for the petrol and diesel would be different. I wonder how that'd work with it being an automatic.
I know in the A4 with the 1.8t the nose, or rather tail (flywheel end) of the crankshaft is different in length and pilot bushing hole diameter. The manual trans crank sticks out further and the bushing hole is different too. You could probably carefully grind it down and have a bushing spun out at a machine shop to fit.
I do not know for certain if the ALH dimensions are different from the gasser, but I bet not since they are mated to similar transmissions.
1 - 7 of 7 Posts
