Trying to swap the engine on a 2011 a3. Donor engine is a cbea from an 09 jetta.
Block casting is different at the thermostat housing... There is an extra hole in the 09 block for a coolant pipe exit...
I can't use the 2011 housing without blocking off the extra hole. Is there an easy solution that is cleaner than using the 09 housing and adding a tee elsewhere to tie in the missing top elbow connection?
2011 motor
8316
2009 motor
8317
Manufacturer: VW, Date(s) Used: 07/2007-07/2009, Model: Bora, Engine Code: CBEA, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
Manufacturer: VW, Date(s) Used: 07/2007-07/2009, Model: Jetta, Engine Code: CBEA, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
Manufacturer: VW, Date(s) Used: 04/2008-06/2009, Model: Jetta Variant, Engine Code: CBEA, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
Manufacturer: VW, Date(s) Used: 04/2008-06/2009, Model: Vento Variant, Engine Code: CBEA, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
Manufacturer: VW, Date(s) Used: 06/2009-07/2014, Model: Jetta, Engine Code: CJAA, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Canada ("CDN") USA ("USA"): Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
As taken from my new VAG Engine & Transmission Codes
