I have a 96 Passat TDI, I'm trying to get the a/c working. It holds freon but is not real cold. The low pressure is around 35psi with a fluctuating needle around 5psi and the high side sits at 160psi or so(which is probably a little low) and slowly climbs to 250 when the fans kick on and quickly drops to about 160- 180 when the process starts all over again. Ambient is around 85 today. Any ideas?
Thanks.
Thanks.
