another question for this week. i know the door locks are vacuum operated, not exactley sure how the system works but i go to lock the doors and the drivers side, front and rear doors, the lock stems or whatever you want to call them, go down but dont stay down. sometime i can get the drivers side door to lock about half way, you can open the door but it only opens about half way. would that be a bad vacuum valve or a broken line? any idea where i should start trouble shooting? much appreciation for anyones help
There's a vac pump in the trunk. When the doors are lock/unlocked a signal goes to the vac pump which powers the pump and moves the door plunger. Look over these 2 articles for some basics on how it works:
http://myturbodiesel.com/1000q_how_to/a3b4/centrallocking.htm
http://myturbodiesel.com/1000q_how_to/a3b4/doorhandlefaq.htm
Look through this for a wiring diagram of the door system:
http://myturbodiesel.com/1000q_how_to/a3b4/keylessentry.htm
It's possible there could be a broken wire at the door hinge or broken vac line.
Discussion Starter · #4 ·
well the passenger side front door im pretty sure doesnt lock either, but im not really concerned because it doesnt open from the outside. the only actual operating door is the pass. rear. it opens form the outside and locks, you can manually push and pull the plunger and it works just fine. however the drivers side front and rear do not go down manually. there seems to be some binding of the parts inside so you cant force it down. the only time it works, and its still only half way is with the key, locking the doors form the outside
