Awesome website, first time poster. I am currently having 2 issues with our 96 passat wagon. The headlights are working sporadically. The day time running lights aren’t working and the low beams don’t work when the headlight switch is turned on (the little green light next to the switch comes on, the maker lights/ instrument panel lights seem to work fine). The high beams will come on if you pull and hold the lever back but won’t click into place and stay on. This problem is seemingly slowly correcting itself. If you drive a little ways and attempt to cycle on the high beams, they eventually will click on and stay on and then you can click them off, the low beams will start to work and the little green light next to the switch will turn off. The run up to this was a low voltage start in which the trip odometer reset itself and the radio went into safe mode (I have sense read the warnings about this). I have only checked the low beam fuses so far and just beginning my quest for illumination, so any help would be greatly appreciated. I couldn’t find any threads on radio reset, can someone please direct me to reset instructions, I do have the radio code. Thanks to everyone that has put so much of their time into making this site awesome and making it easier to work on these beloved cars and keep the diesel faith.
Cheers
Cheers
